Minolta CS Pro 4000
  • gitana1983
    • Mar 2009
    • 141
    Minolta CS Pro 4000
    Happy friday to all!
    I have a Minolta CS Pro 4000 with error code C0410, I searched and I understand that is the "exposure lamp timing wrong" any Idea on how to reset it? or how to fix it?
    Thanks in advance
  • remielee
    Technical Analyst
    • Mar 2010
    • 140
    Thanks in advance
    check the lamp if its working using tester(VOM) test the continuity of the lamp if theres no continuity it means it was busted replace it.
    check the fuser of the lamp if its busted it was cover of black plastic beside the the lamp.
    to reset the eror open the front door in the upper left side theres a small cover plastic unscrew it then you will find the reset button but first check the lamp and the fuse...
    hope it will help you gudluck
    • tonerspot
      • Nov 2008
      • 79
      I had this case in a sunny office, sunlight passing through the vents on the scanner and cause this code
      • gitana1983
        • Mar 2009
        • 141
        Thanks for the help.... I'll post what happened with this machine once we get to it.
        • minimerlin
          • 851
          If I remember the AE sensor was changed for one with a little hood to stop this problem!
          Please do not PM me without asking first.
