Bizhub 350 problem with Microsoft .NET Framework 3.5
  • aleksander
    • 378
    Anyone have any experience with .NET Framework 3.5? I cannot viewing PageScope Web Connection bizhub 350 in .NET Framework 3.5 environment. But if I use Di3510 in .NET Framework 3.5 i can viewing Pagescope Light. So, no problem for Di3510. Problem happened for bizhub 350/250.
    No problem if the bizhub 350/250 connected to .NET Framework 2.0 environment.
    Any solution for this problem?
    Thank you.
  • aleksander
    • 378
    Anyone please help me for this problem. Very urgent. Thank you for any solution.
    • kingarthur
      • 1385
      I seem to remember we had this problem with a customer once, as far as i can remember, if you use Firefox instead of Internet Explorer, then you can access the m/c.
      • aleksander
        • 378
        How about Microsoft .NET Framework 3.5? PSWC cannot be viewed if using this version.
        Thank you for replying kingarthur.
        • aesthetics1
          • May 2010
          • 148
          You need to use a different browser. Internet Explorer will kick HTTP Bad Request 400 errors. KMBS claims that setting up SSL on the machines will fix this (accessing them from https://ipaddress) but this has never been the case. Sometimes it's hit or miss. You can play around with Internet Explorer's security settings and sometimes get it to work briefly.
          • buster68
            • Nov 2008
            • 181
            Update the copier firmware to version 80. Print controller needs to be at version 5.
            • aleksander
              • 378
              ok thank you all. I'll try it.
