bizhub c500 error code SC45-01
  • digipod
    [Error Code] bizhub c500 error code SC45-01
    Hi
    does anyone know what wrong with this machine error code SC45-01
    thanking you in advance
    digipod
  • HORSE
    • Mar 2008
    • 185
    at a guess.... front colour registration sensor is dirty.
    Laughing......
    • RRodgers
      • Jun 2009
      • 1947
      Originally posted by HORSE
      at a guess.... front registration sensor is dirty.
      Yep, or one of your colors is not laying down on the transfer belt correctly. Print out some test patterns in tech mode, do about 90~100 on the density setting. Do it for each color and see which is not laying down properly. Then goto that color and correct it. I usually find it's a dev unit with some blockage to the mag roller. Getting a business card and cleaning it out does wonders.
      Sometimes it's soooo far off you have to go into tech mode and run the color reg adjustment from there as it's more forgiving in tech mode and usually will adjust from there.
      HTH
      And if non of that made sence, call a local tech that works on that box and have them fix it for ya.
      • HORSE
        • Mar 2008
        • 185
        If the machine has been caned you get that toner buildup around the Colour Registration assy. Definitely a dirty sensor I always advise my Techs to vac the grey wiper pads during a PM
        If the colour registration is soooo far off... that would just throw a SC45-20
        I could fix that fault in a dark room... I have done it so many times.
        Laughing......
