Fiery X3eTY2 65C-KM (IC-408) System Software Installer DVD Needed
  • Mickey_uk
    • Aug 2025
    Hi
    I have a Konica C5500 Printing unit with the Fiery X3eTY2 65C-KM (IC-408) Controller, a week ago Controller started giving me "FF" message in its digital led and the scan functionality of the printer is disabled. I look through the posts here and what I could gather was that my controller has a software problem and I have to reinstall the software again.
    The thing is that I cannot find the copy of the DVD anywhere. I was wondering if someone can help me to find the DVD or give the a link to me, I would be very much grateful.
    Please let me know if you need more information
  • HORSE
    • Mar 2008
    • 185
    FF means F**ked Fiery and a reload is required. It could be a faulty hard drive as well but a software reload costs nothing and is worth ago
    You would need to contact Technical Support in Europe to get those disks. Are you KM, Auth Dealer or End user? and where in the UK are you from?
    Laughing......
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      According to the service manual, FF is an indicator that the update is complete. A reboot might be needed of the fiery.
      If the fiery is still operational, that is you can still print to it, then the fiery is operational. Use remote desktop from a windows machine on the same network. Type the IP address of the fiery itself for the connection address. The login name is Administrator (upper case A). Password is "Fiery.1" (upper case F).
      If you can get that far, the fiery is not down for the count and should be recoverable.
      Go to the start menu when you enter into remote desktop on the fiery itself. In the programs list, is the Fiery Tools. Click the Update link. A window will open giving you the update options. Default is to notify you of available updates. I switch this to update automatically, in both the windows and the fiery software. Then I select "update now" in that window. A new window will open up and after a few moments, should show you a list of updates. These are all windows based. They should all be selected automatically. Allow the update to be performed. When it is done, allow a reboot of the fiery. I recommend a full power down instead of a simple restart.
      When the fiery is back up and running, reconnect again into remote desktop, and repeat the above process to the updates window. The second run through will then show the Fiery updates. None should be selected by default. Do not select them all. Only select the items that would be unique to your situation. They should be self explanatory.
      After those patches are applied, reboot the fiery once more. You should be able to use the device as normal.
      And though I have not tried it as yet, you could try performing a system restore, in the same way any windows computer has this ability. As I had mentioned, the FF code indicates that a patch was applied. A simple reboot may be all that is required, but if that fails to resolve the issue, then a restore may reverse the applied patch. Following that restore, disable automatic download of patches and do those manually for the fiery side of the patch update related above. You should still be able to leave windows as automatic, since those patches are not related to the fiery software itself.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • HORSE
        • Mar 2008
        • 185
        Do be honest FF is usually the system not working as it should, I wouldn't be worrying too much about patches or manuals.
        OP try a hard switch off and if the fiery goes through the normal boot sequence and does not make it to 00 and the controller button does not show on the screen you need to reload.
        A power spike can often crash your fiery like that.
        Laughing......
        • Stirton.M
          • Oct 2009
          • 1804
          Pardon me, I should have read a little further in the book on that code. I initially saw the code was as I stated, but neglected to scroll up to see it had to do with USB thumb drive install.
          As for power....stupid power...messing with a perfectly good system....
          ---Groucho Marx
          • Mickey_uk
            Thank you very much guys,
            I am the end user of the printer and located at Birmingham.
            I have tried the remote desktop once before but I would give it a go one more time.
            What I have done to debug the problem so far was to connect the monitor to the unit. When i turn the unit on there is the FF message for like 2 sec then it start counting to 100, while it is counting I can see the normal memory and motherboard check messages on the monitor. when it get to 97 is when unit wants to load the windows OS and at that moment i would get the FF message. what I would see next on the monitor is the OS selection menu (normal or normal with VGA) for a moment then the windows xp logo for sec and then dark screen. I know that there shouldn't be any picture after that. so i figured that the unit is booting but i see the FF message just before windows loading up. I opened the unit as well, i was clean and memory seems to be fine.
            I think it was a power failure because before the unit get busted we tripped the fuse couple of time.
            Just to be perfectly clear the only way to get the reload DVD is to contact the KM support? I looked though their website couldn't find anything so thought i am looking at the wrong place!
            Thank you again
            • Mr Spock
              Vulcan Inventor of Death
              • Aug 2006
              • 2064
              Try this if you want. I offer no warranty as to what could go wrong. I have done this on other fiery's for this code but not a c5500/6500.
              Shut down printer and fiery.
              unplug fiery from wall and machine
              remove the cmos battery (if you do not know what this is stop and call a technician)
              short the positive and negative post of the battery holder together for about 2 minutes
              replace the battery
              reconnect machine
              reconnect power
              power on and see if error goes away.
              I believe that the ff code means (beside f*** fiery) that the bios could not finish transferring boot control to the hard drive
              By the way even the KM techs cannot download the image file. We can order the cd's (as a service part) but not download the image.
              • HORSE
                • Mar 2008
                • 185
                Thank you again
                Sounds like the windows is running but the fiery application is not starting, thats the typical after a power failure without a proper shutdown.
                You need to phone KM and get someone out there... I'm from that end of the world myself and I guess you have a service agreement so just get service to come and reload it for you. If you have just T&M agreement it will only probably be a call out charge.... it takes 54 minutes to reload v2.0 on a IC408.
                The unit usually stays on FF for a few minutes before it goes to 00, what its doing at this time is waiting for the fiery application to start up ... once the unit displays 00 the fiery is nearly up and running. ( controller button will now appear)
                If the fiery application cant start because it is corrupted... it just sits on FF.
                Laughing......
                • Stirton.M
                  • Oct 2009
                  • 1804
                  If you have access to mykonicaminolta.com, you should be able to download all fiery images. 2.0 is the current, last time I looked.
                  The following link will get you to the download files if you have a login account with mykonicaminolta
                  ---Groucho Marx
                  • HORSE
                    • Mar 2008
                    • 185
                    Originally posted by Stirton.M
                    If you have access to mykonicaminolta.com, you should be able to download all fiery images. 2.1 is the current, last time I looked.
                    Is that for IC408? or IC303?
                    I got
                    v2.1 for IC405
                    v2.1 for IC303/305 (system 8)
                    v3.0 for IC305 (system 9)
                    but only v2.0 for IC408 but v3.0 is coming soon. Haven't came across v2.1 yet
                    Laughing......
                    • Stirton.M
                      • Oct 2009
                      • 1804
                      My mistake Horse, I thought 2.1 was out, but I was thinking of the 303/305
                      The original is edited along with a link
                      ---Groucho Marx
                      • Mr Spock
                        • Aug 2006
                        • 2064
                        I posted this without checking. The last time I checked I was using the wrong look up. (I was using fiery x*** not ic -***)
                        Thanks for the link though.
                        • Mickey_uk
                          I got
                          v2.1 for IC405
                          Well I have tried the remote desktop with the Fiery.1 Password, no luck, I am not even sure that the remote desktop service is running at the machine! or the password is wrong. Although when I use my computer I can find the fiery unit in the network section with the name of "OEM-0RDY5LQ9HU" but when I barrows, it has only a printer folder which is empty!
                          On the unit it say:
                          Electronic For Imaging
                          Printer Controller
                          Model: Fiery X3eTY2-10
                          I assumed it is IC-408, I was wondering can you send me the image to me. I can provide you with the part no. if it helps.
                          • Toxic
                            • 698
                            Hi,
                            Few days ago we had problem with ic-408.
                            I guess system were down,display shows FF and controller tab on machine display was grey.
                            We manage to install new system on the controller over network cable after problem with one laptop because it get some error with tftp aplication.
                            When we try other laptop everything pass ok and we put controller back to machine to finish instalation procedure.
                            In controller service manual i see that is posibility to install system from usb flash drive but i dont understand how to make flash bootable.
                            With machine and controller we get few CD ,one of them is system softvare, (one from we installed system) but i can not find anywhere Usb flash installer which is required for instalation system on the usb flash drive.
                            Any help on this?
                            • Christian_W
                              Support Specialist
                              • Jan 2011
                              • 33
                              Hello Toxic,
                              to install a system to a USB flash drive you need the USB Flash installer CD.
                              With this CD you can boot your PC it starts a Knopix system. Than you have to connect the USB Flash drive to your PC and load the system software in the DVD drive.
                              The system will be installed on the USB Stick. After this you can start your Fiery with the connected USB Stick and the system will be installed to the Fiery controller.
                              Christian
