Fiery X3eTY2 65C-KM (IC-408) System Software Installer DVD Needed
  • emujo2
    • Mar 2017
    • 1579
    #61
    Re: Fiery X3eTY2 65C-KM (IC-408) System Software Installer DVD Needed
    The C5500 was end of life 03/2016, the IC 408 went EOL 09/2018..KM has removed all traces of these from the website as of 12/2022. Unfortunately, unless you are lucky enough to reach someone who already has the ISO or disks, you are out of luck. This can no longer be downloaded from the KM site. E
    • Toxic
      • 698
      #62
      I will send you iso file v2 for IC-408 because you contribute to this site.
      Send me your mail in PM.
      • purple
        • Mar 2023
        • 12
        #63
        Big thanks to Toxic, who gave me files. I managed to reinstall Fiery. The controller is active now, but guess what - new problem occurred. When I try to print something I see a message - "the printer is in an error state".
        It doesn't recognize the finisher and asks me to "Load A4, color specific, 81-105 gsm paper in any valid tray" which I guess this is the default paper settings.
        Maybe I need to reinstall the drivers, which I don't have. 😔
        • Toxic
          • 698
          #64
          It asks for paper because default settings is to print configuration report at startup , i always deactivate this in fiery settings.
          You mean driver for PC?
          What driver version you have now and what OS is on the PC?
          • purple
            • Mar 2023
            • 12
            #65
            Hi, I actually have 2 printers with similar issues.
            Now I am working on 6500.
            I think it is with efi 3.0 driver installed.
            When I try to print something from pdf it asks me to "Load A4, color specific, 81-105 gsm paper in any valid tray". I do it and fix the settings, but it still doesn't print.
            • purple
              • Mar 2023
              • 12
              #66
              Sorry, the printer is actually OCE C665
              My other printer is KM C5500. I need to fix at least one, because my clients are waiting.
              • Synthohol
                Certified Konica Expert
                • 5910
                #67
                open command workstation, go to fiery setup and set default paper to plain and turn off start page.
                • purple
                  • Mar 2023
                  • 12
                  #68
                  Sincere thanks to all. 🙏 One machine is already working. I need to replace the fuser belt and start the other one as well.
                  It wouldn't start because I had to add it to Command Workstation after the new install.
                  I have not dealt with such machines until now. I only have knowledge of roll to roll machines. I had no idea that my machines had to be configured through Command Workstation.
                  If I can help anyone, I will be glad if you write to me. Good luck! 🍀
