pro 1051, anyone seen this before?
  • Herrmann
    • Jan 2006
    • 792
    Went to a 1051 this morning, and see, that the transfer belt is torn. Checked all in the area and i can not find any reason for this happening. Mashine has only 750k on it. Someone here who has seen this before and can give me a hint, why this could happen ?
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
  • texchar555
    Senior Production Tech
    • Mar 2007
    • 142
    herrmann, at 750k you will need a pm kit installed. as far as the ripped tr belt i would check to make sure the tr belt unit is not locking up.
    • Arcadian
      • Feb 2010
      • 218
      Re: pro 1051, anyone seen this before?
      have to agree there make sure all rollers are of free movement.
      Good luck
      • protech
        Check all the mylar inside the belt cleaning unit make sure not bent or deformed i have the same issue swap the transfer belt cleaning unit works fine no more ripped transfer belt.
