Bizhub BW 350, softswitch 418 questions...
  • Hansoon
    • Sep 2007
    • 3389
    I recall a post here somebody mentioning that if softswitch 418 bit 3 and 4 are set to 0 the status message and stop operation for the IU are disabled.
    In the manual is written that bit3 must be set to 0 to not display the lifetime message so that seems OK.
    However the manual states that bit4 must be set to 1 to NOT stop operation when IU life ends.
    What's correct to have lifetime message AND stop operation function disabled?
    Hans
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    set "3" to "0". Or even easier, when you choose sohtswitch 418, factory has the next number as "58". Change the 58 to "50".
    Kevin900
    • copytechman
      • Nov 2008
      • 947
      Concur with this, done many, machine runs indefinitely with no msg until cq goes south!
      Regards!
      A.
