Faceup or Facedown?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    How is this for adding mud to an already muddy pond...
    When printing one sided the paper prints side one on the top side of the paper (as loaded in the tray).
    When printing 2 sided documents side 2 is printed first(top of the page in the paper tray) so side one is face down in the output tray. That is why you are getting the results you are getting. If you do not believe me then write side one on a piece of paper put it face up in the tray and print a 2-sided document. This is the nature of most machines.
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Originally posted by dogsbody
      Whats the problem? You said you didn't know why the colour KM's did this with the letterhead setting, I am giving you an answer, were the hell do you get spamming from?
      Sorry about the spam mention, it looked like you were trying to push a product when I first looked at the link you left...a bit related to a spammer post here...see last post in the link... http://www.copytechnet.com/forums/co...ftp-linux.html
      The thread has nothing to do with jamming or how it handles paper. The issue at hand is the programming of the letterhead setting function, in that if any tray is set to letterhead, the machine will duplex the page going through from that tray, and if the paper loaded face up (which would be normal on any other tray setting), anything printed to it gets printed to the backside.
      ---Groucho Marx
      • Stirton.M
        • Oct 2009
        • 1804
        I think it also has to do with print order as well, within the driver, you can set the reverse order, as shown in the print dialog...left side, half way down.
        ---Groucho Marx
        • dogsbody
          • Jun 2007
          • 289
          #19
          Probably could have been a bit clearer, only trying to give some info that I got when training a while back as to why the Konicaminolta colour machines do what they do with the the letter head setting (duplex the page) and why with some offset printed letterhead it can be a problem.
          Cheers.
          The force will be with you always.
          • Albonline
            • Sep 2008
            • 1151
            #20
            this is exactly correct.
            • tcs04
              FORMER Techie
              • 1183
              #21
              I agree!
              I believe all copiers will, when printing from the ADF, try to produce a finished sheet "Copy face down" in the finisher to increase speed and output multiple sheets in the correct order. This means that in duplex they will copy the "top" face of the copy paper with the 2nd side image, then invert the paper and copy the "1st" side for direct face down exit. I confirmed this on the Ricoh machine I worked on today which had the same issue! The only solution was to set one tray with the letterhead paper face up (single sided) and another face down (duplex) then set shortcuts on the machine and driver for the seperate jobs.
              • swt
                • Jul 2010
                • 44
                #22
                Well, we got it working eventually. Or should I say the Konica engineer got it working after a number of hours. The only way it works on the C280 and C360 is to have the tray set on the printer to Letterhead and to have Paper Type in the driver set to Letterhead for the same tray. I'm surprised we didn't get this before as I thought we had gone through all the options. The paper needs to go in face down but we can live with that.
                • JSC
                  Gimp
                  • Dec 2006
                  • 618
                  #23
                  WOW.................So if you had done what Stirton M said 6 days ago, it would have saved a lot of time!
                  This is basic stuff, I find it strange you engineer did not run through this on the 1st visit.
                  The gene pool could use a little chlorine.
                  • swt
                    • Jul 2010
                    • 44
                    #24
                    I think it was Dave10 that asked if the tray had been set for letterhead on the machine but I didn't know where to find that option. I'd been looking for it in the main utility menu and didn't realise that it's set via the Copy menus. I would have saved everyone a lot of time if I'd realised and maybe the engineer assumed I'd tried this.
                    Anyway, thanks for all the replies and input. I'm just glad is up and running properly (for now!).
