c452 552 652 image chips
  • big jase
    • Jul 2008
    • 136
    i have purchased a set of color chips ,but after stripping down the iu i can not see where this chip fits
    has any one replaced any of these ,if so please help
    see pics of iu chip i have etcchip recieved.jpgchip on iu.jpgunder unit where i found chip.jpgunder neath unit were chip connects.jpg
    If at First you don't succeed remove all evidence of ever trying!
  • tcs04
    FORMER Techie
    • 1183
    see pics of iu chip i have etc[ATTACH=CONFIG]5729[/ATTACH][ATTACH=CONFIG]5730[/ATTACH][ATTACH=CONFIG]5731[/ATTACH][ATTACH=CONFIG]5732[/ATTACH]
    Which IU did you strip ?
    • Albonline
      • Sep 2008
      • 1150
      flashing to the special firmware renders rechipping unnessary.
      • big jase
        • Jul 2008
        • 136
        it was the yellow iu i stripped down
        what is the special firmware Albonline..how does that work?
        • mmru4real
          • Aug 2008
          • 67
          the special firmware allows you to turn off stop at end of iu life essentially allowing it to run until the cows come home without replacing until copy quality problems occur
          • big jase
            • Jul 2008
            • 136
            does end user still get message that iu needs replacing....what version is firmware
            • ck1
              • 485
              you take wrong pwb , this is tcr sensor not the drum chip . you photo chip at the first is black color chip , not the yellow. ( sorry poor english )
              • Albonline
                • Sep 2008
                • 1150
                No, the latest special version will even clear the message after it triggers. look it up on konicas tech web.
                • jdallagrana
                  • Mar 2010
                  • 11
                  Albonline, What version, and where on konicas sight? I looked through ssd. any help would be great.
                  • Stirton.M
                    All things Konica Minolta
                    • Oct 2009
                    • 1804
                    On SSD, if you look up the keyword "IU enhance", you should get the details. This is only effective for C250 and newer colour series machines.
                    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                    ---Groucho Marx
                    Please do not PM me for questions related to Konica Minolta hardware.
                    I will not answer requests or questions there.
                    Please ask in the KM forum for the benefit of others to see the question and give their input.
                    • jdallagrana
                      • Mar 2010
                      • 11
                      thankyou very much. found it
                      • emujo
                        • Jun 2009
                        • 3009
                        This fuctionality is built into the 652/652DS/C360 family. You have to set the soft switches correctly, but no firmware update is needed (although I would rec upgrading to B4 ASAP). The firmware upgrade is only applicable to the C203 through C650 family. The user will still see the oil can displayed, but MFP will not stop and IU replacement is elective versus mandentory, and no messages on the LCD to replace IU. Emujo
                        • ebm
                          • Apr 2007
                          • 183
                          What softswitches disable the "End of Life" messages on the C652 and C360 family machines? I tried switch 51 on a C360 showing "Replace Drum K" and it did nothing. Switch 50 only allows black ready ACS. TB6901 disables the prohibiting of copying past the end of life, but it does not eliminate the message on the display. TB7528 is only for the C353 and C650 family machines which "eliminates" the "need to replace" message. I would really like to know how to disable the "Need to Replace" messages on the newer color models. Thanks
                          • jdallagrana
                            • Mar 2010
                            • 11
                            TAUS0647606EN05, TAUS0703722EN01, TAUS0802098EN00 on Konica site may help
                            • emujo
                              • Jun 2009
                              • 3009
                              Sorry gents (and ladies) I was given bad info on the C652/C360. The IU will suspend printing 5K copies past the end of life message. However, I believe KM will offer firmware to make this available on the C652/C360 once they are sure we don't screw up the C650 series by allowing them to run past their life spans. Hope no[one went crazy trying to set this up. Emujo
