i have a bizhub 7145 can scan but not able to print. is there a way to turn on print server has network conection on back of copier but printer setting not lighting up only scan and fax.
bizhub 7145
If I remember right you have to add on the print kit and they did scan right out of the box.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
The first two replies are spot on.
To check if you have a print controller, look to the left of the machine right near the back panel and about half way down you should see an empty hole (presuming that you don't have a print controller all ready).Please don't ask me for firmware or service manuals as refusal often offends.Comment
