Started out as a magenta line going across the image, now the Test copy has all colors faint and light..Total page count is 1307: Color 8818,B/W 489. Drum unit has 84% life remaining on it. Toners are compatible.At this point after removing all the color and dumping all the waste toner from the waste bin of the drum unit,cleaned scan glass, I have ran out of options. Except, does the laser scanner Unit have the same lens,mirror set up as an HP? Any help is greatly appreciated,Steve:
Konica Miolta Magicolor 2430 DL
I don't know anything about these printers, but I do know sometimes blowing the scanners out doesn't work. On some printers I've had to literally remove the scanner and hold it up to the light to swab the lenses with a lint free swab. If there is any hazing you should be able to see it. Check laser scanner & cartridge shutters (if it has them). Hope these suggestions help. I will see if I can get a part number for the scanner for you, but no promises. I think you're on the right track, though.Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!". -
part number of the scanner - 8314139-0763-00
PM me and I'll give you price and availability or since you have the part number you could buy it somewhere else. BTW, it does not cross to anything HP.Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".Comment
