Hi there i am not familar with this box do mainly xerox can any one point me in the right direction ? Konica Minolta Bizhub 350 PROBLEM: fault code c- 0f32
CAUSE: Poor connection between the imaging unit contacts and the machine. Defective ATDC sensor.
SOLUTION:Verify all connections between the ATDC sensor and the machine are clean and connected properly. If the code persists, replace the imaging unit.
C-0F32 is displayed.
CAUSE: Improper operation of sub-hopper sensors.
SOLUTION: Check to make sure the sub-hopper empty switch and magnet assembly are operating properly.
