Konica Minolta Bizhub 350
  • tech9
    • 216
    Hi there i am not familar with this box do mainly xerox can any one point me in the right direction ? Konica Minolta Bizhub 350
    PROBLEM: fault code c- 0f32
  • albasoul06
    COF32 is displayed
    CAUSE: Poor connection between the imaging unit contacts and the machine. Defective ATDC sensor.
    SOLUTION:Verify all connections between the ATDC sensor and the machine are clean and connected properly. If the code persists, replace the imaging unit.
    C-0F32 is displayed.
    CAUSE: Improper operation of sub-hopper sensors.
    SOLUTION: Check to make sure the sub-hopper empty switch and magnet assembly are operating properly.
    • tech9
      • 216
      Thanks mate will check it out in the morning !
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Is this a Bizhub 350, or a Di 350, there is a difference. The code makes me think Di350. The info given was correct. Just change the image unit.
