Bizhup PRO C6500 White line in cyan
Blockshocker
What is Cyan Dev Unit counter? Even if you unblock the blockage, it maybe worth replacing the dev units on the next service. your example don't look that strong a solid even without the white band.Comment
"Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
paulyp3856
Could also be a bit of fuzz or something between the laser and the drum. Area under the dev unit is particularly prone to this. Remove the transfer unit and the cyan drum then use a flashlight on the area directly under the dev unit. Fuzz is sometimes hard to see.Comment
vanman
White Line Fix
Had the same exact Problem. Look at the cyan developer toner roller, you should see a even coating of toner across the length of the roller. In your case there is going to be a gap or a light coating of toner on the area of the stripe. Take a 2" wide strip of 80lb gloss, an feed it in the bottom portions of the roll approx 1-2" until it stops. Then move the strip left and right across the length of the roller. There is a blockage preventing even toner distribution, this will losen it up and should correct your problem.Comment
Hi!
It is clearly a matter of the laser beam not "getting" on the drum surface.
1. Check the "Dust proof glass" - it could be dirty
2. Check UNDER the Cyan Developing Unit to see if there is dust standing in the way of the laser beam.
3. Check the mag. roller of the developing unit to see if it is uniform (or even, how should I say? ). If you can see a lack of developer on the mag. roller in that area where the white line appears, then you should just clean the developing unit.I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?Comment
*shakes head*
Either of you last two guys bothered looking at ALL the other responses? Your contribution is certainly welcome, but you are simply revisiting solutions that have already been stated. Several times in fact."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
trublu
While something interfering between the laser and drum normally produces a sharply defined line, I have had a case where a translucent liquid had been spilt on the print head window, which gave a more fuzzy line.Comment
