Bizhup PRO C6500 White line in cyan
  • drodas78
    • Jun 2008
    • 91
    Hi friends.
    Attached is the picture with the problem I'm getting from the cyan color. The picture is a pattern at 128. I want to have some advice or instructions before getting into it. Please let me know what do you think I need to check for.
    Thank you for your help.
  • costel fasola
    • Jun 2010
    • 69
    drum is ok?
    developer counter...?
    give me some dates here
    • drodas78
      • Jun 2008
      • 91
      Thank you for your quick reply.
      The cyan developer is at 36%
      The cyan drum is at 81%
      Originally posted by costel fasola
      drum is ok?
      • costel fasola
        • Jun 2010
        • 69
        try in 36 mode process ajustement...initialization on cyan unit all steps
        • drodas78
          • Jun 2008
          • 91
          Hi.
          I hope not to bother you. I don't know all the terms and processes yet.
          Would you explain me more?
          - How I enter into 36 mode process adjustment?
          - "Initialization on cyan unit all steps" is a part of 36 mode process adjustment?
          Thank you very much.
          • mrwho
            Major Asshole!
            • 4299
            What direction did that print come out at? Is that an A3/DLT? Or A4/Letter?
            Also, what paper are we talking (type and weight)?
            Mascan42
            Ibid
            • drodas78
              • Jun 2008
              • 91
              The direction is from right to left it came out of the printer in the same way that is the scan. It's a Letter. The lines appear no matter the paper.
              • costel fasola
                • Jun 2010
                • 69
                power on
                9272 start
                36 menu
                process ajutment
                etc
                u need a service manual
                • mrwho
                  Major Asshole!
                  • 4299
                  Okay, so if I understood you correctly, the feed direction was this:
                  So, since you only got that on cyan, I would check the cyan charge corona, the cyan developing unit and the cyan drum, in that order.
                  Mascan42
                  Ibid
                  • hosman80
                    • Jun 2008
                    • 38
                    check your cyan dv unit, it looks like a something on the mag roller.
                    • aesthetics1
                      • May 2010
                      • 148
                      Dust tends to build up in there. Poor design if you ask me. You can clean it off or take a can of dust off to it. It should get rid of the other smaller ones too if this is what is causing it.
                      Otherwise looks like something on the mag roller to me, too.
                      • drodas78
                        • Jun 2008
                        • 91
                        You are right that's the feed direction.
                        [ATTACH=CONFIG]5837[/ATTACH]
                        • HORSE
                          • Mar 2008
                          • 186
                          +1
                          It looks like fluff in dev unit, try inserting a bit of paper between the blade and roller and work it towards the back of the unit. You might be able to work it out.
                          A hair in the laser path under the potential sensor will give a sharp line.... But a hair or speck closer to the laser window gives a more unfocused White line like above.
                          For those who mentioned dirty charge corona.... That would give a dark line
                          Laughing......
                          • drodas78
                            • Jun 2008
                            • 91
                            So do I have to check for hair or speck closer to the image unit window? Can you send me a pic of where to insert the bit of paper?
                            Thanks.
                            • Stirton.M
                              All things Konica Minolta
                              • Oct 2009
                              • 1804
                              I agree...dev mag roller contaminant. Might be fuzz or a hardened piece of developer caught up in the mag/doctor blade.
                              "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                              ---Groucho Marx
                              Please do not PM me for questions related to Konica Minolta hardware.
                              I will not answer requests or questions there.
                              Please ask in the KM forum for the benefit of others to see the question and give their input.
