Konica minolta c450 front control pannel problem
  • maxmax
    • Aug 2010
    • 12
    [Misc] Konica minolta c450 front control pannel problem
    Hi
    I have konica-minolta bizbub c450.
    It doesn't working touch screen pannel.
    Both side keypad is work nomal. only touch screen pannel not work.
    Please help anyone.
  • jackson
    • Mar 2010
    • 19
    replace the LCD panel they cause problems,, the liquid crystal leaks over time
    • mrwho
      Major Asshole!
      • 4299
      Wait just a second. You've got two things: the LCD which draws the image; and the touchscreem which acts as a keyboard accepting input.
      If I understand correctly your question, you can't use the touchscreen to do things like selecting paper or magnification or duplex - althought the image on the LCD is fine. If that's the case, you need to either adjust the touchscreen sensitivity (via the Accessibility button on your left) or to replace the touchscreen panel.
      Now, the parts manual for the C450 doesn't list a separate part number for the touchscreen, but if I'm not mistaken it is the same used on the C250, which is 4037780701. Maybe someone else can confirm this to you.
      Mascan42
      Ibid
      • jackson
        • Mar 2010
        • 19
        Quite right Mrwho , the " touch panel" p/n 4037780701.is at fault , I failed to describe this correctly
        • dogsbody
          • Jun 2007
          • 289
          You are correct, same part number. And I agree, touch panel not the LCD.
          The force will be with you always.
          • mo0651
            • 1054
            FOC bulletin for this touch panel. part # is9981000367FOC tech bulletin# taus0902331
            • maxmax
              • Aug 2010
              • 12
              Hi
              The image on the LCD is ok and the screen changes normally when I use only the keypad.
              But the screen is frozen. When I touch the screen with my finger it doesn't work.
              I can get the touchscreen adjust sensitivity screen using the keypad but as I explained it can't adjust because the screen is frozen.
              Thanks for you tip.
              • mrwho
                Major Asshole!
                • 4299
                Well, then definitelly you'll need to get a new touchscreen in there. The part number is listed above.
                Mascan42
                Ibid
                • firmwareislost
                  • Dec 2008
                  • 8
                  Why cant they make no more good touch screens ??????
                  Konicaminolta in Belgium cant follow to replace them (bizhub C 450)
                  Ricoh has a bunch of machines with bad screens
                  • DCPS
                    • Mar 2008
                    • 116
                    I have found a way to repair them with some kind of "special equipment" .
                    • maxmax
                      • Aug 2010
                      • 12
                      Thanks for replying, everyone.
                      This has helped me a lot.
                      • mrwho
                        Major Asshole!
                        • 4299
                        So, how did you solve the problem?
                        DCPS: Come on, now I'm curious!
                        Mascan42
                        Ibid
                        • hondapol
                          • Jun 2010
                          • 15
                          I managed to fix some too. Its not 100% but better than nothing
                          • AyJayAreDii
                            • Jul 2010
                            • 99
                            well to get by while the new one arrives. Any way you could share how?
                            • hondapol
                              • Jun 2010
                              • 15
                              I have warmed several screens by heating them on a convection radiator then pressing along the edges with a cloth while it is still hot.The problem is caused by the glue they used so doing this fixes the connections, only about 70% successful though. good luck
