Sorry mrwho , since you do not start this thread but...., well is curious about this, so I bother to bring these bulletin to you and the others who responded well in this thread.
This problem with the touch panel also seems to be common in the old DI850/750. appears as an erratic failure,according to some colleagues in the field told me that the problem appear during changes of weather or in high humidity place.
After a while I found one of these bulletin are a good detail of the case.
But more particularly I just wanted to apologize mrwho, you was entangled in a discussion that did not deserve to go ahead, I am not offended with anyone in particular, but you think carefully, all those points Rep P, do not change my prestige in my field, but still wanted to exchange ideas with other technicians, and this is unfortunate.
Good Luck!
The following files decribed this problem in :
bizhub C450, C351
bizhub C352, C300
bizhub C250, C252
GESTETNER - DSm725/DSm730/DSm725e/DSm730e
LANIER - LD225/LD230/LD325/LD330
RICOH - AFICIO 3025/3030/MP 2510/MP 3010
SAVIN - 8025/8030/8025e/8030e
The latter has no relationship with Konica Minolta but may help to understand.
Good Luck!
bizhub C450, C351
bizhub C352, C300
bizhub C250, C252
