host name problem
  • kmbthk
    • Aug 2010
    • 9
    host name problem
    I can't input the hostname when registering smb in pagescope web connection,it shows invalid character .The hostname is xxx_pc1,is the underscore cause this?
  • mrwho
    Major Asshole!
    • 4299
    The simplest way to be sure is to try and register it without the underscore. Different machines sometimes behave in different ways.
    PS: Are you setting up machines on a porno movie factory or what?
    Mascan42
    Ibid
      • 23002
      I had this discussion when setting up a Samsung MFP to scan to SMB. The IT guy set up a rule that all passwords must have a special character. Samsung does not allow a special character on the password line when programming an scan to SMB addressbook entry.
      "Can we create an exception: one password without a special character?"
      "No. That's the rule. It must have a special character."
      "Then you can't scan to SMB."
      blah, blah, blah....
      • jma676
        Expert Tech
        • Mar 2009
        • 323
        Ok, Thank you! and maybe you need post this thread here:
        Connectivity
