Konica Minolta C6500 Y Drum unit
  • pg1309
    • Mar 2010
    • 15
    I get white spots/stripes on my yellow? i can see it on the drum unit, i did clean the blade but the stripe/spot print same place every time, Y drum unit life about 40%
  • HORSE
    • Mar 2008
    • 185
    Thanks for sharing that with us, have you replaced the drum unit yet?
    Laughing......
    • sbillis
      • Nov 2008
      • 95
      You can replace temporary Y drum with one from another colours (C,M,K) also to verify that your problem is drum Y.
      I can say that these stripes are in some cases common problem. Doesn't matter 40% or 90%.
      This is caused because the Y is the 1st DU wich the belt, after the cleaning unit, is getting in touch and maybe the remaining toner wich is not cleaned from cleaning unit is transfered to Y drum.
      • RRodgers
        • Jun 2009
        • 1947
        Ummm... check your dev unit for voids and white stripes in your copies. Be sure the laser path is not blocked as well.
        • don
          Yes, RRodgers is right. Check with DEV unit. Remove the dev powder and filter it check for any dust particle or Dev solid particles. Check the Dev unit roller and see if it has scratch mark on it.
          • jma676
            Expert Tech
            • Mar 2009
            • 323
            Only Replace All***
