7228 scan to box erase time setting
  • kingarthur
    • 1366
    Hi
    I've got a customer with a 7228 on which they are scanning to box, it is set to erase anything in the box after 1 day, i cant seem to find out how to change this setting, i've set up a new box account on the m/c & it doesn't give me an option to set up the erase time.... it's probably something simple (apart from me that is ) but can anybody enlighten me
    cheers
  • jma676
    Expert Tech
    • Mar 2009
    • 323
    Ok, Thank you! and maybe you need post this thread here:
    Connectivity
    • 173545
      • 16
      Description
      How to set the ScanAutoDelete time of document stored to a box.
      Solution
      To set the ScanAutoDelete time, perform the following:
      1. Press the Help Key and then select KEYOPE mode.
      2. Select SYSTEM INITIAL.
      3. Select DOCUMENT FOLDER.
      4. Select SYSTEM BOX OPTIONS.
      5. Select OPTION SETTINGS.
      6. Press the Edit icon to select the desired time, None, 12hrs, 1 day, 2 days, 3 days, 4 days, 5 days, 6 days, 7 days or 30 days and press OK.
      7. Press RETURN 3 times.
