C200 shows document on glass
  • Eugene74
    • 70
    [Misc] C200 shows document on glass
    Good day everybody
    I've got a problem, hopefully a small one, on a C200. If you insert a document in to the Document feeder, it will sometimes, no always show that there is a document on the glass. If you lift the feeder and close it again (I did lift it all the way to the top) and try to put a document in the feeder, the same message display. If I leave the machine to self reset or switch it off/on I am able to make a copy from the feeder.
    Did anybody had this experience before or any suggestions.
    Many thanx.
    Eugene
  • mrwho
    Major Asshole!
    • 4299
    Check the actuator that detects whether the RADF is open or closed.
    Mascan42
    Ibid
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Yep.....I concurr.
      May also be reed sensor problem, the doc feeder is out of alignment to the main body.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • KM7155
        • Aug 2008
        • 146
        Re: C200 shows document on glass
        am facing this problem as well. what i found out is when u closed the feeder (without paper in the platen glass), the machine will detect
        there is paper on platen glass and is A3 size. dismantle the white cover which stick to the bottom of the feeder, solved all the problem.
        but...customer cannot accept this solution....
