C252
  • SPBE
    • Sep 2010
    • 70
    C252
    I have a c252 with an fs514 throwing a c 1183. but the image on the display shows that there are 3 output trays when there are only 2. Has anyone ever seen this?
  • albasoul06
    FS514, error code SC1183.
    Solution
    CAUSE: PC11 sensor is not functioning......Replace PC11 !!
    • mo0651
      • 1054
      The trays have gone past the upper limit sensor. You must lower the trays by hand to make the code go away. Take off rear cover of finisher and you can pull the motor away to lower the tray. Keep upward pressure on trays as you pull motor away or you will hear loud bang. If it happens again, I would check sensor for sure.
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        As mo0651 said.
        Subject:
        FS-514, C1183 (C-1183) error code.
        Description:
        FS-514, C1183.
        Solution:
        PROBABLE CAUSES:
        1. Incorrect tray positioning.
        Remove upper and/or lower tray and remount to correct position.
        2. The ground wire and the 2 red wires for the sorter door interlock switch are not properly seated.
        Inspect the harness and connector for problems with a poor/no connection. Reseat the connection for the door interlock and properly position in the harness.
        3. Accessories improperly installed. Error code will occur when outputting paper to Tray 3 because the lower adjust plate may not be in the correct position.
        Check for correct installation when only OT-601, SD-503 or MT-501 is mounted and when OT-601 + SD-503 or OT-601 + MT-501 are mounted.
        Position the lower adjust plate in the correct position according to the attached OT-601 Installation Manual. The proper placement of the adjust plate is shown on page E-3, Section III. Installation procedures (if Mailbin Kit/Saddle Stitcher is mounted) are in figure labeled 9J06IXC129DBAdobe - Adobe Reader download - All versions.
        4. Finisher may not be level.
        Verify that the finisher is level to the main body.
        5. Timing abnormalities. If an elevator tray starts to move up when paper is close to the upper position in the tray, trouble code C-1183 might occur because of the upper limit sensor chattering.
        There is firmware to help eliminate timing problems. The timer is changed from 100ms to 180ms. The firmware is available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
        IMPORTANT: Firmware version 07 (9J08-F050-G00-07-000 CHECKSUM-6881 Finisher.EXE)
        is for the bizhub C300/C352/C352P and version CBF-00-007 (4038-F050-CBF-00-007(00) CHECKSUM-A599.EXE) is only for the bizhub C252/C252P.
        NoteAdobe - Adobe Reader download - All versions
        or
        Main body firmware>
        bizhub C352: Version GCy-G4 (20060914 9J06-F000-GCy-G4-000(00) CHECKSUM-1EBD.EXE) or greater
        bizhub C300: Version GCy-G6 (20060914 9J06-F000-GCy-G6-000(00) CHECKSUM-BA1A.EXE) or greater
        bizhub C252: Version CBF-00 (4038-F050-CBF-00-005(00)_CHECKSUM-0590.EXE) or greater
        <Finisher firmware>
        Version G00-07 (9J08-F050-G00-07-000_CHECKSUM-3EA8_Finisher.EXE)
        <Procedure>
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
