C351 Fusing unit help needed
  • brilliantsol
    • May 2025
    [Misc] C351 Fusing unit help needed
    Hi all,
    Machine suddenly started outputting creased paper. had a look around and found the fusing unit has a layer of plastic. not too sure if it is delaminating this plastic, or whether it has been fed something (of course no one has fed it anything nasty!).
    not too sure if it should have a plastic layer on the roller and the fuser is just dead or whether it is foreign matter - waiting for the machine to cool at the moment.
    If it's a dead unit, is it an engineer fix or would a competent person be able to change the unit.
    Sorry about the blurry image but the palstic can be seen on here.
    Thanks in advance.
    cheers
    Colin
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    replace the fuser.
    ---Groucho Marx
    • brilliantsol
      Many thanks, now it has cooled and been removed i can see the diff from the other roller.
      Gulp, not cheap.
      • Stirton.M
        • Oct 2009
        • 1804
        Nope, that they are not. Unfortunately these cannot be rebuilt to my knowledge. Someone else might know otherwise, but I doubt it. You might be able to source a little cheaper through Katun.
        ---Groucho Marx
        • Kmdurrin
          Copy/Print/Network Tech
          • Dec 2008
          • 132
          You are correct, Stirton. The C351/450 fusing unit is a "black box" unit and cannot be rebuilt. Part code 4049-523, and precision roller sells it for about $600 shipped. The good news is - its a really easy replacement if you do get a new fuser.
          Parts: Its what your copier craves!
