Location of boards
  • Dedotch
    • Oct 2008
    • 40
    [Dead] Location of boards
    Greetings, I have a Bizhub 6500 that was shorted by a RU-504. I have located and replaced all boards except what a tech called the Scanner Drive Board Assy 65AA9071E and the Toner Drive Board Assy. I can't find them in the parts book. If anyone can direct me to the page or location of them that would be cool. I can get the Scanner Board fixed but not the toner board. If anyone has a used toner drive board I will buy it. Thanks
  • KM7155
    • Aug 2008
    • 145
    u mean bizhub 6500 or bizhub C6500?
    • Dedotch
      • Oct 2008
      • 40
      C6500 sorry
      • RRodgers
        • Jun 2009
        • 1947
        I believe the scanner drive board is located right behind the scanner (under the back top cover) and the toner drive board is located on the toner add system. If you swing out all the toners ( on the big door that they are on) it's right under that cover.
        • Dedotch
          • Oct 2008
          • 40
          Thank you R Rogers. I found them both. Have a blessed day.
