B350/250
  • francois
    service manager
    • 32
    [Jamming] B350/250
    hi, did any one had a problem on the duplex turn over unit that couses the m/c to jam. is sounds like the motor that is not turning, we replaced the motor, the sensor and the soliniod but the same problem is stil there. i have it on 4 m/c and on a B420
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    I am not sure I understood the last thing you said. If you were saying you have a duplex problem on a bz420, then you have 2 motors to change. I have not had a bz 250/350 duplex problem, unless the problem was the switchback unit. If you want to narrow it down, pull the switchback and duplex and go to another machine and test them.
    • francois
      service manager
      • 32
      i have switch the switchback unit with another one, still the same problem. i even upgrade the firmwere on the m/c. the sound what the m/c is making sounds is a grr,grr,grr. i have swap all the boards inside the m/c aswell.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Did you swap the duplex unit?
        • Cantechman
          • Nov 2008
          • 228
          Maybe the duplex clutches?
          • francois
            service manager
            • 32
            i have swap the duplex unit with a new unit and stil the same problem
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              If you have swapped both the switchback unit and duplex, you may want to look at pwb "A"
              • Cleveland Tech
                • Oct 2010
                • 22
                replace the board on the back of the machine, I had the same issue and ended up replacing that pcb. that should do the trick if you replaced the other stuff in the switchback unit.
                • francois
                  service manager
                  • 32
                  hi, i have solve the problem, it was the drum unit, when i swap the drum unit the m/c is working 100% without jams or aboard codes. thanks for all the help you gave me.
                  • BR549
                    • 110
                    I was just about to say change drum unit but I see you figured it out. I had this problem. The drum had a wear line all the way to the bare metal. It arcs to the charge corona causing weird problems.
