C6500 Image Problem
  • seniortech
    • Dec 2007
    • 180
    C6500 Image Problem
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    In tech rep, under process adjustment, select "Recall standard data", select factory and press yes.
    Then back up one level to Drum Peculiarity Adj., select Automatic drum potential and Auto gamma adjustment.
    That "should" help correct the issue.
    ---Groucho Marx
    • seniortech
      • Dec 2007
      • 180
      Thanks Stirton. M
      lLooks like you have seen this one before. Can you explain in a little detail what is causing the problem, Is it that residual current left on the drums is causing an electric (ghost) effect?
      • Stirton.M
        • Oct 2009
        • 1804
        I am not certain what may be the ultimate cause...it could be simply hardware memory related, a quirk with the erase lamp, or as you posited, excess residual charge that the erase lamp might not have been able to deal with in one stroke.
        Of course, this may not resolve your problem, it is just one of several approaches to correcting image issues...
        Did you try this and did it correct the problem?
        ---Groucho Marx
        • HORSE
          • Mar 2008
          • 185
          They will do that.
          Similar to the old Transfer Ratio Trick.
          Laughing......
          • seniortech
            • Dec 2007
            • 180
            Thanks Horse
            Already tried this...didn't work, have to visit this machine again probably in the middle of next week. Machine is a couple of hours drive away so I want to go well prepared with a firm action plan or parts to try and resolve the fault. What I an not prepared to do is just throw parts at the machine until the fault disappears! At the moment apart from what you and Stirton have both suggested I haven't a clue what I should do to try and reslove this fault. Going to get the file run out on another machine to check if the problem is with the file, but gut instinct tells me that this is engine related, other ideas or suggestions all greatfully received.
            Many thanks
            • seniortech
              • Dec 2007
              • 180
              Got the file tested on another machine today, came out perfect, I now know it's an engine fault
              • tervel12
                • Dec 2008
                • 65
                What is the distance between the image and the ghost image? Looks like about 58mm on my monitor, but not sure if your file was scanned at 100% or if it was enlarged/reduced.
                • Chromatik
                  • Aug 2010
                  • 71
                  unclear points here, it would be important to know what is the meaning of the direction of the posters here (Mainscan / Subscan?) also can see the whole image, an image appears unreliable.
                  In any case seems to have a problem with the stabilization control is so erase lamps do not work properly, if so after a certain number of impressions you would see this repeated throughout the image area.
                  Another question: is this the first Print? or what? is a copy or Print?.
                  Anyway banding of Halftoning has no relation to what this picture shows.
                  • Herrmann
                    • Jan 2006
                    • 792
                    how old are the drums? if they have too much mileage, they are getting "tired" , resulting in residual charge remainig on the drum
                    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
