Konica C253 (Olivetti MF250) Dropping Black Developer - See sample attached
  • pajeroid
    • Jul 2009
    • 130
    Have a C253 in the field with the sample problem (attached). Anyone have any experience of this? It doesn't seem like the PRCB problem as this is only on the first page... This gets worse on about the 3rd page.
  • suso73os
    • 38
    How many copies does it have?, I think is an image unit problem, there is a collar in the magnetic roller and may be wasted.
      • 30332
      Bad IU unit
      • pajeroid
        • Jul 2009
        • 130
        Sorry, it has had a new black IU & transfer belt.
        • Stirton.M
          All things Konica Minolta
          • Oct 2009
          • 1804
          Looks like developer dumping, which could be poor bias contacts, failing hv....does the print feel gritty? Is there any developer beneath the unit inside the machine?
          Check to ensure the erase lamp is clean, along with the laser window...not likely those are the cause, but I've been surprised before.
          "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
          ---Groucho Marx
          Please do not PM me for questions related to Konica Minolta hardware.
          I will not answer requests or questions there.
          Please ask in the KM forum for the benefit of others to see the question and give their input.
          • pajeroid
            • Jul 2009
            • 130
            Hi, yeah the prints feel gritty so definatley developer.... I will try the HV Board & Cleaning this afternoon and report back =)
            • rprem
              • 49
              change this iu to another machine and see the problem comes in that machine also so the iu unit may be defective
              Head Lines Are Made When Dead Lines Are Met
              • minimerlin
                • 851
                Did you ever crack this problem? I have the same on a C253...but only when running paper settings that are Thick!! ie Thick1 shows slight problem and as the paper setting gets thicker so does the amount of dump..see my post of C253 K iu problem. I was at the customer today and found that on plain paper all is well!! Weird!
                Please do not PM me without asking first.
                • pajeroid
                  • Jul 2009
                  • 130
                  From memory I believe we had a faulty batch of black imaging units. The faulty IU's had a skewed drum blade and when corrected; solved the issue. We have had only one since so the problem is still around it seems. If you need precise instruction I will speak to the engineer who solved this issue and get him to write up some instructions. =)
                  • minimerlin
                    • 851
                    I would welcome that information , still wierd that the problem I have only shows when thick media used tho.
                    • pajeroid
                      • Jul 2009
                      • 130
                      Solution to incorrect developer doctor blade position
                      I have had a chance to speak to the engineer this afternoon and we put together these instructions for you... Hope this is the issue you are experiencing!
                      • minimerlin
                        • 851
                        Many thanks for the detail, I will try that on one of the image units that gave the fault and let you know the result.
                        • fishleg
                          • Mar 2009
                          • 426
                          mmm how are you reseating that doctor blade even ? Probably just me...
                          Think I tried that trick once and it was hell I could never get it right. A gradation out of the machine was all over the place.
                          • pajeroid
                            • Jul 2009
                            • 130
                            Literally just push it towards the drum with your finger.... just make sure not to touch either the doctor blade or drum with your finger as you will damage the surfaces. Also remeber the drum surface is light sensitive, try to do the work in a dark area - certainly nowhere near direct sunlight.
                            Once you have adjusted the position, spin the developer using the drive at the rear of the unit and you will see if the developer is evenly distributed.
                            • minimerlin
                              • 851
                              Went back today and did the blade tweek ...seems to work!! Ran 400 prints single sided and duplex on a variety of thick stock all came out ok! No sign of any build up on the IU top at all. Lets hope that this remains as a fix!
                              Thanks for the info.
