Konica 8031 - fiery problem
  • mcprest
    • Sep 2010
    • 19
    Hello. I have an konica 8031 with Fiery printer. the copier runs great, but when start the fiery printer it shows me "Fan error". This error appears only on fiery display. The copier runs ok, only i can not print.
  • Albonline
    • Sep 2008
    • 1146
    open the firey up and check the fans????
    • RRodgers
      • Jun 2009
      • 1947
      Its probably the cpu fan, as stated above crack it open and see if they spin freely.
      • albasoul06
        M24 is the cooling fan motor.
        • mcprest
          • Sep 2010
          • 19
          I have found a cooler on this fiery that was blocked. I have change it, and fiery runs great
          Do you know how big (minimum) has to be file memory and work memory on PWB-F ?
          • Albonline
            • Sep 2008
            • 1146
            256 meg ddr 266mhz
