bizhub 421 problem
  • aleksander
    • 378
    bizhub 421 problem
    Hi, I have problem with bizhub 421. The copy output from bizhub 421 has erased at the trailing edge and always stop working after printing 400 sheets.
    Please give me solution. Thank you for all answer.
  • copytechman
    • Nov 2008
    • 943
    Can you clarify the second issue? As for the first, if it's what I've seen before, clean the trans/sep corona's thoroughly! That should help a lot!
    Regards!
    A.
    • rajeevminolta
      Hi,
      Try upgrading the firmware.
      Raj
