Minolta DI650 - SC35-01
  • jmsaugus
    • Jun 2025
    [Error Code] Minolta DI650 - SC35-01
    I have an error code SC35-01. I change the DIPSW8-3 to 1 and 8-2 to 0 but still have the code.
    need some help
    thanks
  • mrwho
    Major Asshole!
    • 4299
    I don't know why you'd want to mess with SW8-2, but if the SW3-1 to 0 doesn't solve your problem, then you have a physical problem on your fusing unit. It could be a bad thermostat, bad temperature sensors, bad fusing lamps, even a bad connection between your fuser and the machine.
    You must check it out, or, if you don't know how, call a tech.
    Mascan42
    Ibid
