Bizhub C5500 - C3801 error code
  • MFPTech
    • 486
    What is the following error code related to please?
    Thanks in advance!
  • dogsbody
    • Jun 2007
    • 289
    Fusing low temperature abnormality. Could be any of the temp sensors, lamps, AC driver board or printer control board, or it may just need to be reset.
    Cheers.
    The force will be with you always.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      This can occur if the paper weight is not set correctly.
      • MFPTech
        • 486
        [Bizhub C5500] [C-3902 / C-3903 error code]
        reset the Switch 3 - 1 to 0 and I got C-3902
        cleaned the one-way bearings in the fuser, reset the error again and now I am getting C-3903. The lamps, thermostats and thermistors look okay with the multimeter.
        Any ideas, please?
        Thanks in advance,
        • CKiiza
          • Feb 2010
          • 77
          That's for:
          Fusing high temperature hardware
          detection abnormality.
          Temperature sensor/4 (TEMS/4)
          detected abnormality signal continuously
          for the specified time.
          check one of the sensors you touched or worke[IMG]file:///C:/Users/Moses/AppData/Local/Temp/moz-screenshot.png[/IMG]d on. might have a problem
