C0510 Error code on Minolta Di550
  • nizar642
    • Sep 2009
    • 16
    [Error Code] C0510 Error code on Minolta Di550
    Hi,
    I have a Konica Minolta Di550, and today it stopped working causing an error saying C0510, How to fix it? i've checked out the orange fuser ( i don't know its name in english ) and i found it colder than what it's expected to be.
    Nowadays the weather is cold here in my region. Any ideas of how to bypass this error?
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    when you open the front door, on the left side there is a small panel with one screw. Remove and there is a trouble reset button on the small board. The code was for the fuser and you may have bad thermistors or lamps.
    • nizar642
      • Sep 2009
      • 16
      Thank you so much! i've fixed it by adding a lamp to the one that is already exists ( there was only one ). and now it's working!!!
      • brent
        • Nov 2008
        • 1214
        are you saying that there was only one lamp in that fusing unit? there should be an upper and a lower heat lamp. the di 470 had 2 uppers and one lower.
        I would be curious how that machine worked missing a fusing lamp
        brent
        • nizar642
          • Sep 2009
          • 16
          Hi Brent,
          Yes, there was only one lamp because my region is so hot in summer and now it's cold and that what caused the error which means a very low temprature.
          Thank you very much for taking the time to get more explantion!!
          • brent
            • Nov 2008
            • 1214
            I forget sometimes that these machines go to different countries. thanks for the imput
            brent
