Stuck on "Now Warming Up"
  • xxxbambixxx
    • Sep 2025
    Our secondhand bizhub 250 is stuck on "Now Warming Up".
    Turning it off and on won't work.
    Before this problem occured, there was a paper jam in the first tray but we couldn't find anything so we did a trouble reset and that's when the "Now Warming Up" message occurred and hasn't gone away since.
    Please help? Thank you.
  • rocky246
    • Feb 2007
    • 91
    Does it sound like something is running when it says warming up. If so, I would check the toner bottle. The machine will cycle the bottle looking for toner and display warming up while it does this. I've had people call for this and 2-3 hours later when I arrive it still says warming up. Remove empty bottle and install new. Give it a few minutes to add toner and it takes off and runs.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      It is looking for toner, I bet the bottle is empty.
      • Techead42
        • Mar 2008
        • 32
        xxxbambixx, are you positive the message is "Now Warming Up", or is it perhaps "Please Wait"? If it's "Please Wait" you may have a bad NIC card.
        • xxxbambixxx
          I'm positive the message was "Now Warming Up".
          strangely enough, after being turned off for the weekend, the copier is once again working.
          i do think it may be the toner because the copier did make a sound like it was perhaps cycling something? for future reference, is there a way to check if the toner is low before it gets stuck like that again?
