Bizhub Pro C500 SC36-06
  • mailderrick
    • Mar 2010
    • 131
    i know this is related to the fuser but what part specifically..i dont have the manual on this one. Before this error showed up the guy described to me the smearing page on half the page so i told him possible thermoswitch..but before i could call him back to find that out he had called anohter company. the guy came out and told him he needs a whole fuser (machine has 337,000 pages) and he said the are melted gears one thumps when you turn it and he showed him...also that there is a missin part of fuser web? then he left and later the error came up..i still think the biggest problem may be the thermoswitch. i have not seen it yet but might get the chance monday. Thoughts? also ...does the error reset by opening and closing the door?
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    The thermistor on the upper roller is experiencing the issue.
    It could be as simple as a dirty sensor, failing sensor, or a failed heat lamp.
    To correct the code, you will need to enter 25 mode, set switch 3-1 to 0. The rest is simply taking the covers off to observe if you have a failed lamp during operation. Eliminate that and it is likely related to the sensor itself.
    We stopped using the webs, they tended to stall the fuser too often...melted gear? More like missing tooth? A visual inspection should be made, but to say he needs a whole fuser unit? What kind of crack is that other tech on? These units are serviceable and almost never replaced...upper and lower rollers, bearings, the odd sensor and even gears are replaced, never the whole unit. I suspect that other tech is a hack....someone not worthy to work on this machine, it is obviously too complex for them.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • Techead42
      • Mar 2008
      • 32
      Mailderrick, I would do my best to get a copy of the service manual on this; I've service the C500 series for a number of years & more recently the CS650, these machines produce a decent color copy but there a number of image quality adjustments that need to be performed after PM parts are replaced; having the service manual is key, as it has an adjustment matrix outlining adjustment steps to be performed, the order in which they need to be performed, etc.
      • mailderrick
        • Mar 2010
        • 131
        ok., i dd find a manual to download although it is not complete it does have most of the basics for this machine. It shows to go into mode 36 "8050" , i don't have the jig but i can order it or use other ways of measuring..i think the manual i have mixed with the previous knowledge mixed with a few techs and this forum will get me through the new machine although if you have a copy you would like to share i won't turn it down:-)
        • sanimir
          • 183
          PM for you
          • sanimir
            • 183
            manual ok?
            • mailderrick
              • Mar 2010
              • 131
              It is ..one of them i had; the other i did not - so it will be very helpful. I have a few manuals myself so if you ever need anything hopefullyi can repay the favor!
              derrick
