We just had issue with a C353 black toner. They had message to replace toner. Then just got "warming up" wouldn't come to ready.
Had OEM in it and replaced it with OEM.
After resetting the trouble then there was a slight gear grinding sound by rear of fuser area and sound like a solenoid not engaging so gear slipping. Then trouble code said replace waste toner.
Waste toner was almost empty. reseated checked IU, Toner etc. Still gear noise with a sound like a gear slipping due to too much back pressure.
We eliminated fuser and transfer belt as possible problem.
Appeared to be toner back up in the cleaning auger .
Nothing in manual about accessing toner cleaning system (I later found out why)
To isolate what was causing - hours later having disassembled 3 layers of boards, motors frames and housing got to the toner cleaning system to test- took off interface gear and when hand turn waste supply could tell the toner clean system was binding. HOWEVER, to get the actual toner clean system out, we we have started dismantling from the front and can't really see what all has to come out. Appears may have to pull more from the right side or probably take out all supports for the IU's and the under supports for the toners. However, then there appears to be another section blocking the waste toners.
Looking in the parts manual, the waste toner supply isn't just one section it is a series of smaller components. (Almost seems that the waste supply feed system might have been the very first item added to the frame
Hopefully someone on this forum has already solved the dismantle nightmare and shed a little light
Thanks in advance
Thanks in advance
