Konica4345
  • cliffhangers
    • Feb 2010
    • 242
    Konica4345
    KONICA4345 it is displaying error code F23 help.THANKS IN ADVANCE.
  • 173545
    • 16
    Toner supply motor abnormality.
    • mrwho
      Major Asshole!
      • 4299
      Check this:
      DESCRIPTION: F23 while copying.
      CAUSE: F23 is a toner add failure which may be caused by the recycle toner collection pipe not properly aligned to the developer unit.
      SOLUTION: Inspect the alignment; correct if necessary.
      Mascan42
      Ibid
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        If I remember correctly it was very common for the little white gears on the Dev assembly toner mixing, to wear down and stop turning. This would cause toner to back up in the toner delivery tube. If you slide the dev assembly out and see the hole where toner enters packed this is likely the cause.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
