Shadows on printed materials with Bizhub C253
  • nenebrown
    • Oct 2010
    • 9
    Shadows.pdf
  • mrwho
    Major Asshole!
    • 4305
    That's very odd - it seems to me that your problem is related to the cyan IU, but I'm not sure. Can you try copying that original in each CMYK color separately?
    Mascan42
    Ibid
    • nenebrown
      • Oct 2010
      • 9
      Thanks for your reply. The 4 Units are brand new. We replaced them all few weeks ago, and now we will replace the PRCB and the Belt too. I found out a solution here in the forum, to the problem of first page scattering in Black. My printer does the same when I send a job. Here is the topic: http://www.copytechnet.com/forums/ko...cattering.html
      I also found this Internal advise from Konica Minolta, attatched here: bizhub C203-C253-C353 Grey Background (First Copy Out).pdf
      • mrwho
        Major Asshole!
        • 4305
        I also found this Internal advise from Konica Minolta, attatched here: [ATTACH]7634[/ATTACH]
        The only way to be sure whether replacing the board would solve either or both of those problems is to replace it and try it. If you're already going to replace the board, why not do it and then experiment with it?
        Mascan42
        Ibid
        • nenebrown
          • Oct 2010
          • 9
          • mrwho
            Major Asshole!
            • 4305
            Disponha sempre!
            Mascan42
            Ibid
            • nenebrown
              • Oct 2010
              • 9
              Problem solved
              We changed the PRCB and the printer is ok now. Thanks again, this forum helped me a lot.
              • mrwho
                Major Asshole!
                • 4305
                Mascan42
                Ibid
