konica minolta biz hub 200
  • copierlady
    • 338
    Working on a biz hub 200 it has void lines every once in a while. Not consistant. I thought it was a flat spot on the fuser, that is what it looks like but that is not the problem. When it does happen twice in a row the void areas are about 3 inches apart.
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Pull the IU and look inside. There is some cheap foam around the erase lamps that fall down and block the laser, and look inside the IU. I just took a paperclip out of one.
    • copierlady
      • 338
      Ok guys hate to admit it but i came into the shop today! Trying to wind up somethings befor i take a short break for new years. Here is a scan of my issue. I also found when checking the drum unit that there is a scratch pretty deep on the far right side out of the line of site on the copies.
      Tried to coat it with fingernail polish. I thought it helped, but after about 15 copies the problem came back. The polish could'nt wear off that quick could it?
      Thanks[ATTACH=CONFIG]7679[/ATTACH]
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        That scratch is most likely the drum coming in contact with mag roller. T collars go bad and it causes quality problems. There is a thread called Bizhud 250/350 eating drums. It will shed a lot of light on this.
        • copierlady
          • 338
          Ok guys thanks i'll check it out.
          • solis557
            • Dec 2010
            • 53
            It looks like to me the developing unit is starting to fail
            • teckmate
              • Mar 2010
              • 4
              light areas
              Looks like toner blocked in developer unit. Drag paper along mag roller may clear blockage, but usually comes back.Change developer usually cures problem.
              • galumina
                • Sep 2010
                • 32
                There is a slight possiblity that the Developer needs to be changed. and the doctor blade cleaned that should take care of lines.good luck
                • solis557
                  • Dec 2010
                  • 53
                  if you are going to replae dv you might as well replace dv unit at the same time
                  • SmellsHot
                    Head Tech
                    • 512
                    dont forget to look at the transfer roller. There are white arms on the end of the transfer roller that come into contatct with the drum unit. If these are worn funny on either end it will also eat your drum unit like the dev collars do.....
                    Everyone has the right to be stupid. Some people just abuse this privelage more than others
                    • mrwho
                      Major Asshole!
                      • 4299
                      Just to throw another twig onto the fire, check if your drum has aluminum on sight where there shouldn't be any - if there is, it could be arcing and causing that kind of problem.
                      Mascan42
                      Ibid
                      • solis557
                        • Dec 2010
                        • 53
                        if you replace drum unit, dv, dv unit and transfer roller all at the same time this machine will run a long time without cq problems. I worked for km and parts were readily available and i know how hard it can be for mom and pop shops to get the parts, but if you do this and change the drumlife counter to off you can almost get double the life from this unit.
                        • Millennium
                          • 30
                          I can not reiterate just how important this is. We have had techs replace the drum AND DV unit and forget this only to have a call placed on them within a month with the same issues.
                          The transfer roller is a $20 part that will save you a ton of money in the long run if replaced in a timely manner. The drum scratch on the right side (along with probable damage to the rear side DV seal) are both symptoms associated with the transfer roller also being worn.
                          • Hansoon
                            • Sep 2007
                            • 3349
                            Hans
                            “ Sent from my Intel 80286 using MS-DOS 2.0
                            https://www.copytechnet.com/images/smilies/biggrin.png
                            • KEVIN900
                              Copier Ninja
                              • Oct 2009
                              • 200
                              I just re-read that entire thread. What a learning experience. That was a total Think Tank.
                              Kevin900
