Bizhub 250 Fax Driver Available?
  • aesthetics1
    • May 2010
    • 148
    #16
    Just to confirm you have set this up in the program, correct?:
    EDIT:
    Have you seen this also?
    Subject:
    Server connection error when PC-faxing. Other PCs are able to fax.
    Description:
    Solution:
    CAUSE: Anti-virus scanning of the PC-fax is causing the job to time out.
    SOLUTION: Configure the Anti-virus program to not scan PC-fax jobs.
    Any anti-virus software on the PC? Any of the other PCs exhibiting the same problem?
    I would recommend completely disabling any firewall software temporarily. McAffee, Norton, AVG, Eset, etc.
    In addition to the FK unit, have you also installed the extra memory?
    • mrfuser
      • 1625
      #17
      yes, exactly, just different IP of course.LOL
      • aesthetics1
        • May 2010
        • 148
        #18
        A-ha! The .50 address is the only acceptable address for a networked MFP device!!! Glad to solve your problem..... </sarcasm>... hahaha.
        • Shadow99
          • Jun 2010
          • 11
          #19
          In order to PC-fax from this model, you must turn "Gateway TX" to on(allow) from restrict. This is found under the admin/network setting screen.
          • aesthetics1
            • May 2010
            • 148
            #20
            I believe the gateway TX setting only stops the machine from printing the jobs instead of faxing them out, but I could be wrong. I haven't encountered that personally.
            • mrfuser
              • 1625
              #21
              I had actually turned that on right away. Does anyone know what SIP-FAX is in service mode? It is disabled currently.
              Kelly
              • Shadow99
                • Jun 2010
                • 11
                #22
                SIP-Fax is for VOIP or internet faxing so it should be off.
                • zarazek
                  #23
                  Re: Bizhub 250 Fax Driver Available?
                  I have the very same problem. Trying to print document to "Network fax for windows" driver in order to fax it out via bizhub doesn't work. It results with "server connection error" message.
                  Enviroment:
                  Bizhub250 with fax module. Network Fax software installed on PC (WinXP_ProSP3) with the bizhub's local network IP number set (192.168.0.150). No firewall, no antivirus. "Gateway TX" in bizhub's configuration set to ALLOW.
                  Any ideas?
