I tried another ram pack and nothing (from another biz 500- just to see if turns on or not)
Bizhub 500 blue screen
Firmware related. Like what was previously mentioned, you will more than likely have to reflash the f/w. Send the boot (ganges) file first than follow it up with ver20. Then upgrade to ver 31 after that....gotta do it in stages depending on the level of f/wEveryone has the right to be stupid. Some people just abuse this privelage more than others
black dust
You can extract the boot sector by making a small adjustment to the ISW firmware program. I'll see if I can find the bulletin on it.Parts: Its what your copier craves!Comment
BeardedOne
The easiest fastest fix, is if you have a working BH 500, copy the files from its CF Card ( be careful not to format the card )and paste them onto the CF Card of the non working machine. The only issue with using this method is all the information from the working machine ends up in the other machine so you have to do some reconfiguring once its up and working.Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI BoxesComment
SOLUTION: To enable the boot file to be loaded into the ISW utility, perform the following:
1. Using Notepad (or another text editor) open the ”ISWTrns.INI” file from the C:\Program Files\KONICA MINOLTA\ISWTrns folder.
2. In the environment setting, change [EASYTRNS_MENU_DISPLAY] from [FALSE] to [TRUE] and save the file.
3. Restart the ISWTrns tool.
4. In ISW, Select the [EasyTrnsFile (T)] dialog from the Options(O) menu.
5. Browse to the boot file.
The boot file is in the version 20 firmware.Parts: Its what your copier craves!Comment
black dust
black dust
I have a bin file named
50ge000m0g140000.bin
does any one have the 20 or 31 version???
this could be use to upload:
