c452 WITH LINES
    • 30440
    c452 WITH LINES
    GOT A C452 WITH LINES THAT LOOKS LIKE THE mfp BOARD FAILURES ON THE C353 AND C451 SERIES MACHINES ANY INPUT WILL HELP THANKS
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Could be a board failure, check firmware, do a factory reset (backup user data first), inspect connections and reseat. Use ledger size paper and see if the pattern repeats, it could be a damaged transfer belt.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • emujo
      • Jun 2009
      • 3009
      To me, the lines don't look like anything electronically induced, more like rubbing or stalling somewhere. What happens when you scan an original to a scan location? Are the lines reproduced? Emujo
        • 30440
        Scan work fine, get lines on copy and print and internal printouts
        • mo0651
          • 1054
          Boy those look like laser dots. Seen those when a laser malfunctions. How about doing some single color copies and see if it is one IU or all 4. Might help tp narrow it down.
          • pepper38_cnd
            Field Service Manager
            • Aug 2005
            • 1075
            If I had to guess I would say the transfer belt cleaner is plugged up. Pull out the belt and see if the lines are on it.
            Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
            Now into Ip TV KODI Boxes
              • 30440
              pull transfer belt no lines on belts but on 11 by 17 line does repeat that is about the size of black drum ,but CQ look like the digital lines failures of the c353and c451 MFP boards?
              Is there any word from konica on a special firmware for this model to address digital type of lines?
              • Mr Spock
                Vulcan Inventor of Death
                • Aug 2006
                • 2064
                If it is a repeat pattern then I would try another drum and see if it goes away.
                  • 30440
                  Lines in all 4 colors light gray about 1 inch band, check and reseated all drums,
                  • mo0651
                    • 1054
                    Okay that sound like something stuck in t-belt cleaning blade. Stop the machine with paper at transfer and then look at belt. That lite gray sounds like waste toner not being cleaned.
                    • lucky13
                      • May 2008
                      • 125
                      what have you replaced so far?
                        • 30440
                        black drum no change going to try MFP board do to the fact it looks just the c353 and c451 banding problem we had from the MFP Board on the previous model
                        • kronical
                          Kronic Copier Ninja
                          • Nov 2009
                          • 230
                          You said the deefect repeats on 11x17 sheet, is the defect always the EXACT same? Run the internal cmyk test pages, if you see black/grey lines throughout the colors, then i/u's and lasers can be eliminated. you would then be looking at tbu, secondary transfer, or fuser. If you say the defect repeats at about the interval of a drum rotation, i would check for ripples in the fuser rollers, as they are about the same size as a drum.
                            • 30440
                            MFB board fixed it.
