Dialta DI250 !!!!!!!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    hello
    it is my first Experience with This Type of machinery (DIALTA ) Where is this damn message !!!!!!
    (The imaging unit must be replaced ) and somtimes she make err COF 32
    what mean this message exactly
    pleas am wating helps me.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    The image unit is the drum unit. The code is for the developer. You must replace the drum unit or rebuild it. The message gets reset with a fuse in the new unit.
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      Thank you very much friend
      fixthecopier
      DAMENE ABDEL AZIZ
      DJELFA
      • pspice2001
        fixthecopier
        sweet is right but I have found that ordering a rebuilt drum unit for these POS is almost impossible to get a good one. They usually leak from the mylars being distorted so if I were you I would look at the one you have and if no leaks rebuild it. Much easier then cleaning dv from the machine and pulling the registration clutch to clean and all the bushings
        • sweet.persona
          Engineer
          • Nov 2009
          • 414
          it is weired !
          thank you friends but there is NO fus in the drum never!!! it is weired!
          DAMENE ABDEL AZIZ
          DJELFA
          • minimerlin
            • 851
            The fuse is behind the connector unit that plugs the unit into the copier. It is a little green item that looks like a resistor. It is covered by clear plastic insulation
            Please do not PM me without asking first.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4724
              The image unit can be rebuilt several times. If the rear mylar seal is torn and leaking toner it can be replaced using a di-183 rear seal. Also to prevent this from happening again replace the rear white spacer. There is a new style spacer sold by densigraphix. The seal breaks because when the spacer wears it allows drum to get to close to seal. The rear side is the only side this happens to because the image unit drive is on the rear.
              • fixthecopier
                ALIEN OVERLORD
                • 4713
                The fuse is not glass, it is a pico fuse. It is a small green oblong ball with wire coming out of each end.
                • copierdude1
                  • Jan 2011
                  • 12
                  The Image Unit is inside the left side door. You should either order a new one or order a rebuild kit for it. If it was still making good copies you can cheat it by simply replacing the pico fuse. If you pull the image unit out and unscrew the connector that is attached to it you will see a green thing that looks like a tiny resister except not with the color coded stripes. This is the pico fuse. Replace it. Push it back in the machine and let it run. However, since you were getting COF32 Malfunction, that means your toner to developer ratio is off. The only solution then is to replace the developer which is included in the rebuild kit we spoe about earlier.
                  • Bedul
                    Maybe this could help. Try jumpering the resistor in connector imaging unit. Attach, switch it on again, then there is an initial message error C13C0, turn off, unplug the jumper, and turn on the copier. Hopefully this way managed to trick the copier. For COF32 code, try setting the ATDC sensor gain value between 7 and 19%. Also check the gear wheel as well the shaft on the magnetic roller. Replace if damaged. The prints will fade and disappear altogether when the gear wheel and shaft damage. Hopefully helpful.
