Bizhub C450 problem
  • irakli3443
    • Sep 2010
    • 42
    Bizhub C450 problem
    when I printing some part is not print good
    look at simple
    please help
  • mrwho
    Major Asshole!
    • 4299
    Cyan IU.
    Originally posted by Irakli3443
    look at simple
    Yup, that one's simple.
    Mascan42
    Ibid
    • tonerspot
      • Nov 2008
      • 79
      did you reset the IU ? maybe you need some developer on cyan IU
      • irakli3443
        • Sep 2010
        • 42
        and how can I check it? wich one have problem? Red Blue Black or Yellow?
        Sorry for my littel English
        • mrwho
          Major Asshole!
          • 4299
          Blue
          Mascan42
          Ibid
          • Stirton.M
            All things Konica Minolta
            • Oct 2009
            • 1804
            *sigh*
            Replace the Cyan image unit.
            "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
            ---Groucho Marx
            Please do not PM me for questions related to Konica Minolta hardware.
            I will not answer requests or questions there.
            Please ask in the KM forum for the benefit of others to see the question and give their input.
            • irakli3443
              • Sep 2010
              • 42
              mrwho
              maybe problem in Toner?
              • ineo+6501
                • Mar 2010
                • 262
                Have you just had the BLUE IU chipped?
                • irakli3443
                  • Sep 2010
                  • 42
                  I dont know.
                  I had this Machine 2 month, my friend presented it.
                  so I'm bigginer
                  • ineo+6501
                    • Mar 2010
                    • 262
                    Well in any case, you need to fit a new CYAN IU.
                    • mrwho
                      Major Asshole!
                      • 4299
                      If you have another used Cyan IU, try it to see if problem changes.
                      Else you can try to add toner from the tech rep mode and see if problem goes away permantently.
                      If nothing works, then my betting money goes to a new Cyan IU.
                      Mascan42
                      Ibid
                      • irakli3443
                        • Sep 2010
                        • 42
                        yes but some IU have life, look at attachemnt photo
                        some body said me the machine is probably at an angle, it's posible?
                        • mrwho
                          Major Asshole!
                          • 4299
                          It is possible, but if that was the case, your machine would show that defect in all colours. Since only the cyan is failing, we're assuming your cyan IU was chipped (reset) and thus it is probably not new. Look at your Cyan drum: does it look entirely new? Or do you see a big difference between the edges and the center?
                          Mascan42
                          Ibid
                          • Stirton.M
                            • Oct 2009
                            • 1804
                            A level machine is important, but mainly to keep it from rolling around. If it was unlevel, you would see the issue in ALL the IUs, not just a single one. The IU's sometimes die prematurely.
                            As mrwho stated, the "add toner" command in tech rep may correct this issue and sometimes does, though not often.
                            ---Groucho Marx
                            • Stirton.M
                              • Oct 2009
                              • 1804
                              JINX!
                              ---Groucho Marx
