---Groucho Marx
yes but some IU have life, look at attachemnt photo
some body said me the machine is probably at an angle, it's posible?
It is possible, but if that was the case, your machine would show that defect in all colours. Since only the cyan is failing, we're assuming your cyan IU was chipped (reset) and thus it is probably not new. Look at your Cyan drum: does it look entirely new? Or do you see a big difference between the edges and the center?
' "But the salesman said . . ." The salesman's an asshole!' Mascan42
'You will always find some Eskimo ready to instruct the Congolese on how to cope with heat waves.' Ibid
A level machine is important, but mainly to keep it from rolling around. If it was unlevel, you would see the issue in ALL the IUs, not just a single one. The IU's sometimes die prematurely.
As mrwho stated, the "add toner" command in tech rep may correct this issue and sometimes does, though not often.
---Groucho Marx
JINX!
---Groucho Marx
