C452 with Copitrak
  • kingarthur
    • 1369
    C452 with Copitrak
    Has anyone had to fit "copitrak" to a biz C452, if so,can you tell me where it needs to be connected to the machine
    cheers
  • stepwik
    • Nov 2011
    • 17
    Re: C452 with Copitrak
    I'm looking at doing the same with a KM bizhub 552 (not "C"). My random guess is one needs to enable twain scanning on it, and as such it would be done using a separate network drop (ie the 2 machines are connected to the switch/router rather than directly to each other).
    Did you end up doing this? How did it go?
    cheers
    Repair Reduce Reuse Recycle Rejig Retire...
    • kingarthur
      • 1369
      hi
      the company who supplied the copitrak did it....but they made a right mess of the way they left the wires hanging down...cos everytime the customer had to open/close the r/h hand door...they had to move the cables out of the way to stop them getting trapped
      • emujo
        • Jun 2009
        • 3009
        You need to get with copytrack..give them the model # and they should supply the correct interface cable. You can find the copier cable under the right upper cover (Optics Section). Then you need to get into service mode and turn on the vendor mode. Emujo
