konica1120
  • cliffhangers
    • Feb 2010
    • 243
    konica1120
    good day and thanks for being so kind.i just fine out that the toner motor is not feeding the developer unit.what can i do to solve this problem so that the toner motor will send toner in the developer unit.i really need help on this.thanks in advance.
  • remati
    • 149
    ...in tec mode "4" "7" you see de motor ,run?...the gear and the drive shaft, run..?
    -If the answer is yes...change the developer and make the developer adjust..
