Imagistics DL650/Konica Minolta 7165
  • Jerry
    • May 2025
    Supervisor just told me I will travel 200 miles away next Monday to work on this copier the tech there can not fix. I have worked on these before (not trained) but not sure about this problem. Page says the doc feeder is cutting off image. Would anyone have the sim #\'s to adjust this? I will talk to the tech tomorrow and get more info. on the problem and will repost more then. Thanks guys!
  • kronical
    Kronic Copier Ninja
    • Nov 2009
    • 230
    Re: Imagistics DL650/Konica Minolta 7165
    There are no Sims on these, just straight up service mode. Check and adjust your scan area and ADF size sensors.
    • Coptech
      worker drone
      • 460
      It has been a lot of years since I worked on those but best I recall, the registration sensor was really prone to getting dirty and intermittently cut off the lead edge print of originals. I think a plate on the underside of the feeder drops down and exposes sensors. I think they can even pick up damaged mylars and cause same thing.
