Bizhub C550 jamming like crazy from top tray
  • MFPTech
    • 486
    Bizhub C550 jamming like crazy from top tray.
    Cleaned feed tires, sensors, no difference. Before replacing the clutch thought to check here if there is any other ideas.
    Thanks in advance!
  • RRodgers
    • Jun 2009
    • 1950
    I'm sure you've check to be sure there is no paper behind the tray? Size set correctly?
    • mo0651
      • 1054
      Clean feed shafts, check/replace oneways. We had the orange rubber actually peel free from the center plastic core on these feed tires.
      • MFPTech
        • 486
        Now, both T1 and T2 are jamming. The second sheet is stuck between the feed and sep roller.
        Replaced the entire feed unit and does not make any difference ...
        • trublu
          Check ICP15 on the paper feed transport board is not open. If it is it will stop the paper feed clutches working on both tray 1 and tray2.
          If this is the issue, check for pinched wires to theses two clutches.
          ICP15 2A CL1 Tray 1 paper feed clutch Paper Jam at 1st paper feeding section
          CL2 Tray 2 paper feed clutch Paper Jam at 2nd paper feeding section
          • trublu
            Of course, you will have to replace the board, too :-)
            • erodz85
              • Mar 2011
              • 11
              Re: Bizhub C550 jamming like crazy from top tray
              Did the clutches fix that for you? i've replaced both pick up assemblies and still jamming. Boards been replaced as well. what am i missing here? lower feed door latch was broken, replaced that and still nothing. I'm at my wits end with this damn machine. i hate that i can't see things working!!!!
              • habik
                • 2014
                Is your bypass tray working? (feeding)
                How about Tray 2,3 and 4
                Where exactly does your paper stops? Jam codes? Report?
                Firmwares HERE
