BH 162
  • montana
    • Aug 2008
    • 392
    BH 162
    hi..konica minolta BH162 with black lines on the both sides of copy size A4..i replaced the drum & blade but still the same black lines on the copy A4.but when i changed the paper
    orientation to A4R the copy come out clear with no lines...the total counter 203309..
    any one seen this..i apreciate any help
    thanks............................................ .......
  • minimerlin
    • 851
    Sounds like either the dev unit has a problem with the drum spacers and/or the transfer roller is worn out, or the grid/charge can is dirty.
    Can you see the lines on the drum? Can you post a scan of the problem print/copy?
    The reason the A4R copy/prints are clean is that the paper position is then in the middle of the feed path and A4C is using all the area therefore any marks at the top and bottom of the paper will show up.
    Please do not PM me without asking first.
    • montana
      • Aug 2008
      • 392
      hi...thanks minimerlin ..please could you tell me the life counter of the transfer roller...is it time to replace it on the counter..203339
      thank you...
      • Chip Resets SA
        • Sep 2010
        • 46
        Have you checked the mylar strips on the developer roller. Also check the dev roller spacers. Is it a solid line or broken up and wavy?
        • minimerlin
          • 851
          thank you...
          Transfe roller should be changed at 150k. The white horns that run on the drum wear and then the unit can damage the drum.
          • montana
            • Aug 2008
            • 392
            hi...thanks mr.chip resets for reply...yes it is a solid line on the left side of copy A4 & wavy light line on the right...
            hi mr.minimerlin so i should replace the transfer first then i will see what happen
            thank you gentlmen ..
