bizhub PRESS C8000
  • Christian_W
    Support Specialist
    • Jan 2011
    • 33
    #16
    Re: bizhub PRESS C8000
    Hello texchar555, here in good old germany we have a "Oktoberfest" and we have a PM-Kit for C8000 .
    The partsnumber for this kit is A1RF-SMP.
    Christian
    • magdykonica
      #17
      Dear All
      I need to know the coast per click compaerd to c7000
      is it higher or lower ?
      Thank you
      • jrf
        • 142
        #18
        I have 2 machines in field but find the charge coronas are very poor compared to 6501s. Also the drums are not lasting and transfer blades also wear quickly but quality is excellent once all units are replaced.
        Could you please update your expierence with your machines
        • jrf
          • 142
          #19
          Are any of you having trouble with C8000 main scan registration and if so what procedure are you using to resolve it.
          Example is 3 to 5 mill movement of image on SRA3 which can occur at random.
          I would appreciate any feedback.
          • racefreak
            • Sep 2010
            • 30
            #20
            Jrf...... I'm having the same issue on mine. I've heard that if the customer runs mainly coated stock, the registration roller needs to be cleaned well and replaced often. My machine has just over 1mil on it and I've replaced that roller 3 times now. Also, the sub reg rollers right before it need to be replaced periodically as well. I'm still getting random movement so I've ordered a registration motor for it. That should be in on Thursday so when it's in we'll see how that works.
            • jrf
              • 142
              #21
              How is machine on 170 or lighter coated stock. Do you get many jams in RU unit.
              Thanks for information Racefreak
              • racefreak
                • Sep 2010
                • 30
                #22
                Not sure what the gram weight is on this but they run a lot of 80# text weight. I believe that's around 150 or so. That runs fine no jams in the RU at all. If the humidifier is installed, you might need to check the cams on the water rollers. I did have a case where one of the cams was off and was applying a very light coat of water when the rollers were supposed to be cammed open. It caused so questionable jamming only on a Williamsburg paper. I believe the weight was around 136.
                • jrf
                  • 142
                  #23
                  Ya it's running well now on lighter stock,
                  I think it was just a height adjustment needed at RU unit
                  • spatech
                    • May 2010
                    • 1
                    #24
                    We have installed three C8000, with several problems of parts life. After consult with technical boss and calculate real cost we conclude the our price of print is more expensive compared with C7000 for example, and omitting repair time (fuser and transfer with complications). But for client is a wonderfull machine.
                    • Tonyrey35
                      #25
                      hi can anyone help i have the disk for the ic-601 color centro but i need a newer version to work with the c8000 does anyone know where i can download this thanks
                      • methogod
                        • Dec 2008
                        • 927
                        #26
                        i cant find anything that says it works with the C8000, have to do some more reading.
                        If you know the version you need let me know.
                        mike
                        • Tonyrey35
                          #27
                          mike
                          hi thanks for getting back to me i think the version is color centro 2.1 and this should work with the c8000
                          thanks
                          • methogod
                            • Dec 2008
                            • 927
                            #28
                            i can send it to you, PM me your email.
                            • Juan Ant
                              • Oct 2012
                              • 13
                              #29
                              hello.
                              I do not know where to download the latest version of the color center. could you tell me where to download it?
                              a greeting
                              • methogod
                                • Dec 2008
                                • 927
                                #30
                                There was a repo'ed C8000, double fuser, ru, finisher on ebay for 15K, tried to grab it for 10K, and it was gone at 15K in 4 hours.
                                That would of been a nice hit.
                                Don't know if i would of kept it in my shop or flipped.... but I've played around with the c8000 and its impressive machine we run alot of 9 and 12PT Coated and C2S so having a machine that can duplex 300gsm instead of the current 250gsm is really a huge improvement in our market.
                                Everyone is right about the price, but i am sure when the new C7001s start to hit they will start to drop the C8000 for less, maybe 30K a unit some deal with the C6500 when the C6501's arrived and so on with the C6501's when the C7000 series arrived.
                                i was told they fixed the life issues with a new intermediate transfer system on the C8000 is this not true...
                                i like going 300K+ between pm's - i get 150K-180K before DV fails on my C6501 and C7000 (a little longer)
